ChristianMariner
- Joined
- Jul 1, 2013
- 131
Re: Intex Mariner 4 modifications and Tips
I run a 17# and I seem to move along just fine, even with 2 180+ adults. However, a friend of mine has loaned me his 40# endura. I will be using it this weekend and I will report back the difference. Instead of 2 180+ adults this time, I will have My G.F. , Her son and myself... so it will probably be about the same as far as weight is concerned.
Speaking of reporting...
I was trying to open a boston valve ( number 2 ) to "top it off" while in the water... the whole thing came out and chamber #2 deflated...while I was trolling along in the middle of the lake. I didn't sink. The motor went under us, luckily I carry the pump with me. I pumped it back up, the motor came back to its right position and we continued along.
So, even if one chamber goes flat, you will survive and not take on any water.
Yes, I know not to do that again!
The more trust you have, more push you get, therefore faster you should be able to move. However in reality when you try to move faster, you have increased resistance from the water. So upping from 40 to 50 does not mean automatic increase of 25% of speed. This is probably difficult question to answer as the most of the people don't have the experience of comparing the two on Mariner 4. I choose 55 lbs because I wanted to be able to move my boat against current and wind. My 55lbs moves my mariner about 4.5 mph ish.
I do not believe you will save battery juice with bigger motor. It is the other way around with 5 speed. If the battery life is your main concern, you should go small with 5 speed. Hopefully wind does not pick up too badly.
If you have variable speed motor and wanted to move your boat at the certain speed, in theory you will be using same amount of trust and drawing the same amount of current no matter if you have 40 or 55, if everything else is equal (but they are not). You will be turning the knob more with 40 lbs than 55 lbs. However, this does not mean you are using less battery juice with 55 because full throttle with 55 lbs use more current than 40 lbs.
