what size is the bolt that has sheared,try drilling a hole in the middle and use what we call an easy out tool,you tap the easy out tool down the hole that you have just drilled and then you turn it anti CW and hopefully the broken bolt should come out,give it a spray with plus gas overnight before extraction.
