I guess I missed where he said he was towing with it.just tow it without the cover on
I dont see where the OP wants to tow with the cover on. I also recommend against that. He was simply looking for options on lashing the cover to the trailer. many of the custom fit covers come with straps with clips and hardware to do just such a thing
Thanks for your responses,
I've had many different cuctom covers made through the years, all trailer well and all had snaps with draw string, my new cover has a 1" web with ratchets to secure, he also gave me some loops on sides of cover for straps, he didn't want to install snaps on my new to me Cobalt, which I appreciate,
Most of the straps I can wrap around trailer frame, there are two loops on each side that the fenders, (tandem axle), interfere with mounting straps, thinking about adding some "pad eyes" to secure straps. I have been using my two piece cover, (bow&cockpit), that came with boat for trailering which allows me to leave my bimini top up, for long distance I want to use either my new mooring cover or two piece with bimini layed down.
My goal is to be able to use mooring cover, as the two piece lets rain in and changing covers back and forth is a pain
Mine has the 1" ratchet style and a connection to each transom loop and the bow loop., but no way (or need) to attach straps to the trailer. The benefit to the ratchet style is that you can get it cranked tight enough under the rub rail that it can't come off.
Do you trailer it like that? no tie downs?
I have made/sewed a lot of towable covers and have never seen a ratchet system like that. Very interesting.
Oldjeep, is yours like that too? Care to take a picture of how it hooks to the front?
I'm glad to here that you can pull these without straps, I cranked mine down tonight, pretty snug aroung bow and stern, sides are loose enough that I can slip a couple fingers in.
I'll give this setup a trial run next time I take boat out, and hope the cover doesn't land in someone's windshield behind me.
Thanks for the input oldjeep
The front sheds all on its own. One pole in the back when moored or you get some minor pooling.Does your cover fit tight enough that it sheds water.
