Hey guys, I have a 2008 8.1L Mercruiser that came to me in pieces from a machine shop. The owner of the boat was getting frustrated with the machine shops inability to put the "extras" on the block so he handed it to me with the best of intentions and a big grin. I've put the beast back together and she looks great and is just awaiting its test fire but I've come up with one huge problem. This particular engine has a remote oil system that mounts to the port-front side of the engine. Also on the port side of the engine is a heat exchanger which the oil lines are routed into. The oil line at the rear of the heat exchanger goes to the fitting near the oil filter block off plate. This plate is the part that takes place of the old oil filter location before routing to the remote oil filter. So my question to you fine folks is... Where does the forward oil line go from the heat exchanger? The line has a memory that would suggest that it screws into a block plug in the side of the engine, (see pics) but after removing the plug I've realized that the hole is WAY too big. See pictures. I can't find literature on the oil routing that actually shows where it goes into the engine at. There are two smaller plugs that are under the oil filter block off plate but the hose doesn't want to head in that direction naturally. Any suggestions would be greatly appreciated!!
Ok my computer will not play nice with photos. I'm sure you can picture my problem location. Thanks in advance.
PS My computer seems to have issues posting as well so there may be a duplicate post.
