Rehab SportCraft 222 1983 deep V hull cuddy walkaround
kcassells
I did some non skid with the soft rubber medium today.Weather was tricky but I snuck by. Yapped with Mike, @ woodonglass about alot of approaches and suggestions. He always has great insights. Unlike zool
who's busy tending his grapes.
I have to say the soft rubber medium is a good for me. 1st time doing it and I'm happy. Took the paint and came out nice
1st shot makes me happy.
Click image for larger version  Name:	2018_0908_101452_002.JPG Views:	1 Size:	779.9 KB ID:	10799401Click image for larger version  Name:	2018_0908_095859_002.JPG Views:	1 Size:	571.1 KB ID:	10799410
Dang lot more to go ya see.
kcassells
No Eric,
No its not. But you can do that method
. This applying the skid into multiple areas,
I decided awhile back after all my looks that I wanted this method.
sphelps
I really like how the rubber stuff turned out ! I’ll be exploring options for the Manatee at some point ..
Im sure you’ll hav 2 or 3 years of use on your deck before I’m ready so you can report back on how it holds up .. :facepalm:
kcassells
Chipping away with the soft sand anti skit product. Very easy to work with and make small repairs. Here's how I did this part.
Tape out and do radius corners. I found that it needs to be done in quadrants. Too much area to do at once. If mixed into
paint then yup apply all at once. I used a broadcast method. {wife's cinnamon/sugar shaker...oopps.**
Click image for larger version  Name:	2018_0910_032111_001.JPG Views:	1 Size:	439.5 KB ID:	10800022Click image for larger version  Name:	2018_0910_032117_002.JPG Views:	1 Size:	456.3 KB ID:	10800023
Soft sand area and wipe with acetone.
Apply paint using 3/8 nap roller. Adds a build up of paint.
Broadcast product over paint.
Let it set for a few minutes.
Then take a sponge roller and go gently over the particles that helps push them into the paint.
Walk away for an hour.
Click image for larger version  Name:	2018_0910_040039_001.JPG Views:	1 Size:	458.8 KB ID:	10800024Click image for larger version  Name:	2018_0910_060053_001.JPG Views:	1 Size:	394.6 KB ID:	10800025
Use a vacuum to pull up the loose particles. Be careful not to let the vacuum pull you into the paint. It's still wet. If it does and you bugger a spot you can add more rubber at the end to fix it. I had a couple of spots that needed attention.
Click image for larger version  Name:	2018_0910_040049_003.JPG Views:	1 Size:	510.4 KB ID:	10800026Click image for larger version  Name:	2018_0910_071753_002.JPG Views:	1 Size:	445.6 KB ID:	10800027
Now roll again with a 3/8 nap roller. Walk away for an hour or so.
Then come back and pull tape off at a 45 angle away from sand.
Click image for larger version  Name:	2018_0910_040045_002.JPG Views:	1 Size:	468.5 KB ID:	10800028Click image for larger version  Name:	2018_0910_074518_002.JPG Views:	1 Size:	433.8 KB ID:	10800029Click image for larger version  Name:	2018_0910_074509_001.JPG Views:	1 Size:	395.2 KB ID:	10800030Click image for larger version  Name:	2018_0910_074524_003.JPG Views:	1 Size:	424.2 KB ID:	10800031Click image for larger version  Name:	2018_0910_074533_004.JPG Views:	1 Size:	426.9 KB ID:	10800032Click image for larger version  Name:	2018_0910_060058_002.JPG Views:	1 Size:	355.9 KB ID:	10800033
Click image for larger version  Name:	2018_0910_071749_001.JPG Views:	1 Size:	447.9 KB ID:	10800034Click image for larger version  Name:	2018_0910_074659_001.JPG Views:	1 Size:	517.0 KB ID:	10800035
nurseman
looking mighty fine Mr. Kevin. I have a can of that waiting for me when I get back at my project. I am working at getting all of my extemporaneous projects done this fall so I can hopefully put her back into the shop and get into it again. Daughters tree house, wife's sewing table/workstation, camper, :blah::blah::blah:
AShipShow
Son of a diddly, that is lookin gewd! How did you like the soft sand rubber, I'm hoping mine turns out noyce
kcassells
I like the texture. Uses a lot. those areas took to bags 16 0z. ea. @$28.00 ea. I does feel like a rubber and not like a sand.
Time consuming for tapping but I like the look.
kcassells
And onto the next great adventure. Looking for ideas on side mount foldable seats up front. I have some ideas in me mind but if someone has ideas or seen something let me know. Pics would help. :joyous:
Oh yea ...has to be teak. I'm looking shower stall seats in teak. They work.
