Chipping away with the soft sand anti skit product. Very easy to work with and make small repairs. Here's how I did this part.
Tape out and do radius corners. I found that it needs to be done in quadrants. Too much area to do at once. If mixed into
paint then yup apply all at once. I used a broadcast method. {wife's cinnamon/sugar shaker...oopps.**
Soft sand area and wipe with acetone.
Apply paint using 3/8 nap roller. Adds a build up of paint.
Broadcast product over paint.
Let it set for a few minutes.
Then take a sponge roller and go gently over the particles that helps push them into the paint.
Walk away for an hour.
Use a vacuum to pull up the loose particles. Be careful not to let the vacuum pull you into the paint. It's still wet. If it does and you bugger a spot you can add more rubber at the end to fix it. I had a couple of spots that needed attention.
Now roll again with a 3/8 nap roller. Walk away for an hour or so.
Then come back and pull tape off at a 45 angle away from sand.
