Jigginglow
- Joined
- Dec 27, 2014
- 106
Pretty interesting that is wasn't a woodruff key but rather just a round pin that locked everything up......
Quite and adventure hey! Are you going to change that helm or rebuild it? Looks like it's still in nice shape.
Someone must of fueled up on a heaping dinner of Lutefisk! :lol:
A new Teleflex rotary helm with NFB steering cable. I would not waste my time trying to rebuild a cable pulley system but that's just me.
Took a few pics today for reference.What set up does your donor boat have? I can't tell from the pics if your Lark has a tilt tube or what kind of remote steering it had on it from the pic.
If you go all new the you'll need to shop for a complete steeringe system, steering wheel and maybe some parts for the motor as well. Does your motor have the tilt tube on it? You may need a steering arm for the motor too. Iboats here has some Uflex Seastar complete systems with helm and cable.
What is the windshield made of? If glass make fillers as WOG mentioned. If plexy, you might be able to sand or cut to fit.
I debated using 1/2" but settled on the more rigid 3/4". The CSM glass was selected so I could waterproof the deck with the polyester resin. Any extra stiffness gained would not be terribly beneficial I suppose. Thanks for the encouragement! I'm going to get closure on this project this winter so stay tuned for more details.Looks good. Continueing should be a good winter project. Are you adding glass to increase stiffness, or so you can use poly resin? I used epoxy coated 1/2 in ply and my deck stiffened up nicely after adding pour foam underneath. What deck covering are going to use? Keep up the good work!
