zool
- Joined
- Aug 19, 2012
- 3,433
As far as the stringers go, do I have to grind all the old epoxy from the hull? There is a raised area along the stringers that is bonded to the hull. All the epoxy is removed from stringers. I was hoping to use the old epoxy as a guide when I bed the stringers. Also the stringers do not go through the bulkead. I have ground all the old glass and tabbing from the hull where the plywood was loose. I know it's a lot going on so please understand if I'm all over the place. I wan't to take advantage of any material I have out at the time.
No, you just need to have it clean...as long as its adhered. Just a note, what you are grinding is polyester resin, and roving....what you are applying is epoxy resin, and biax cloth.
Just keeping the terms straight
