FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Thanks, that sounds promising as the sleeve costs as much as the yoke, and it already has a sleeve on it.
It's a 1982. How does one tell if it's the type that requires rolling torque?
The gear came off easily with a slight pry if that makes a difference.
There's a 3.8" and 2.25" ring between the bearings if those are the ones you mean. By hand pressure I meant a very slight pry with a screwdriver to get it started and then it slid apart.
When you shim the vert gear and check it with the tool and set the height of the vert and length of the horiz gears . That's why you should have found some shims in the horiz shaft. or still in the case. You can reuse the nut but when its tightened hit 3 sides of the nut with a edge of a flat chisel.to stake it.
