Glen-L WB Power Skiff Build
zool
Nope, you have to take my word on it...Ive gotten nowhere in the past few days...I swear ;)
zool
Update:
Today I flipped the skiff back over and set it on some 4x4s....I need to get the interior layout in and will have to screw into the sides..so Ill flip it back over later to finish the fairing and bottom paint.
y4mbQLKdpi7Zv8kNsCHiOVE8Kk24LxgzTZieJSPvC4xSnhGCjGExIK-DWay4hwi-sc_ojKBvZeCCeRC0Pjb8-4CmLALvMhKRso9nmEae3jx3khS5zsHM9edBFGjHxkxYECAPSMKsmGXecNBbibwnHVvkXshWLzuPHLBoXP2zD6Rn7JBDSaIqfuDCf32xUyhB9_0XwgdHzHDNt8dNRvThDEaJQ
y4m2x9-WoXvRtl32nd7iut8IeIsWgHT2pcG-3l_vk1s24FCCleTeVvfOteB6T8GxRJMzOB4Z9J1rq3IgM2bD1zEZkGEwKkhEVd39XFUf_WzA-Ge0Fu70QnDM9i8RJ3RromEn_c4s9moYOy1HnE0d867PZIsGJ9FGZZ4Gm2kOT4SDW9wnD4goKBO42_0NnhFqzPyTmz9POs5HZLAh88JCrXlng
I cut out the side sections of the frames.
y4mWcbZv8pZnOgk6F5SAhLd4KaNi-ULbE5GGhWjDOrk32pjWgUQNj69OAX0Khhdbf4BpMgwUJ8OpKkjz0Dz6eXVPzIbqlruh5ZJHTUCXvxO5r6hTVQPq4ER8dO8xHnZ-dMww9XKEU18E9osO_Ig6k9BhUcYeG0azfK8_N_SukU6c9sN1gh0VhOlWwwPxc9JU-j2b5y_AjQNegmENHHU3WTzzw
zool
Then I removed the back frame and trimmed it to fit a bulkhead for the mid ship bench.
y4mKBxytLiHHdawb-7Niwn2bpVIU8CFxJG9SchQDH12ueTMfDwQXW9VOAWTP8JJuVptLmdaCm5qGhMklBYA9ut7qkHotnApk098f49TUETc_mnGikZow-5f34_QuBejR5pnPT9d5S1YPSKi9UQN8oWcY_CX9z-b0Y8GrSwZHsoi_bWQUvaMpKAeauJRqitdQ0ppVvDiFpvYAOr4H3jb15eTww
y4mx_woLQmWjQ1uLPpZbgQJqu2upMbgVffp2DLlu7zYy5haovn6uvvmGtPRk1eVziAv2YQm3mZlrChY9oSkB1uLYdrwtadz98WtOF0Ud6Ta2Py2QXrjdtCqXKCMiarvkN7Eq-j_SG0D7bywGTkxVgV0WH-N7FMHbyxNoRKccyVjbVD_CAKCkAElJ610TFtbd6Nq-Mivt_T8kkOEHXHpNDHqag
Pcolafisher
Zool, looking good, nice to see you back on it. There too few threads on building boats from scratch on here. Cheers
zool
Thanks Guys, gonna head over to HD later to pick up some 3/4 foam boards to fill in the spaces between the ribs before the deck and side panels go on...
zool
Update:
HD didnt stock 3/4 extruded foam board so I went to Lowes and got it, along with 1/4 bc for the deck, and 1/4 ac for the sides.
The mid and aft frame pieces were starting to warp so I removed them and decided to make the seating in MDO...
y4mVqoJJZoe1mFmRGBXkhokmfHkqifGGNuqe8BuquCtmhETqW3xENm4zzx7tZE5l0kjSZk-pY0JlB-M3FnD1SmU2zBRK8v6-e2VCS8HlUt-Picxj2gjtuyzibeiGFCoAK8lFl3TfL-e-JS-1dB6gt5B6hF1KxYMP1PZ4LaZmCovL5AWrdbwZbGMlL-px3qzlGsaql5LzEVs6rkhUYBOIPrU8Q
y4mcEqohR80_9iIwNnOZVV8Jdq2KvwZKkfVyKaFP3QE-QfhqPfZhqMpJSjUv5pxSZ_XPLkr8oP-Dy8U3Ko82M694J7BarvXlQ-eFCh1Ub0e9Olwn-C5c16qS71KBhS5unNdY3Rg12mFXCtf2XA9i9GS5lbD6lGOXIIb-FOV07R-zEVVu4lF4ArQtiGEsilbjDvVCRPm_3cdtqRRQy8k2e0RWA
zool
Using longer screws than then ones that fit was convenient at the time, but was time consuming and tedious now, but time to pay the fiddler they say...took about 1/2 hr to grind them all down..in hindsight.............
y4mdZWpJigqUmWr_bLnXNpFm-18Cy6Orf28gOzRKOsZ538wFCykLMuhexD07bNOWbqULXOWjVgusTyg_sxSF8qybtlNyOgCiOa-xzgwnNyqv16-pBTpyUSlsWYQ368HexeEeQ2tDfexy7dPDEQh8j1G3tTRDDh8zmhHcdTe8b3F_EjgWsw2Cw79Y8aPUbDw7JQPHOeM-JZXq_67xNBzhHdIxA
So I ground those down and added some cleats for the deck.
y4mdXcgZav1WgxgtO91sqfhXk6qVmdaXJ3T5YOw-4C3EQmnjlVsY9G-uxAqT12BmMoCcKGDcpv2DIEtDlwcFy0v6n_Z2VvYxX4SN3ujiKzJo03Pj1a6KYqLSdU8h1Jj3cFpvZDB0iD2GZVpPPxb3vtSaiSBlU-hg2JNTQsB8RjqnlpIfl567SDEWTSnarXkyRhEcfRiPeArxcyFxB69R2j4Rw
Then I started fitting the foam between the "stringers"....
y4mlovX1RPJfS_C1yaz_aBHvVG03POonh0-DTxeRthSjJ_1Z-407lDOLxhqFA1CMbEAjGlpaYikKcJliQ_SBCvKP7ExioykWPGdW7PdgbfJX_LkDDklVFxaV7JQI10uQ0iaMinvDMNVOBZZA1PNek4Zz3ucJYmLfLIo25nmWw_kCCt3ZNhWsga6p0WBD0YmYnTjzyuXvrPw9Q7mqy5HQB1D0Q
zool
The center pieces were pretty straight forward, but the outer pieces were a real pain, being a compound angle and rounded....so it was pretty much cut, set, cut again, set, cut again ect.... but they are done
y4moOajnKffoM8uKYOvjUyiiP28dx7-J-ldNJzGYZY8egSfrvnFJwQPEZAsHDBAN3TyQnyiNUmiJDGMARDKaRdPUzJ4sk_70IOrUzh7iSx3cmJr3ugUdUh3gJCVT0LteSKOH00RBJ3syXRTjNZd1X1neU4jgmpd-fIG1gV8xggET0qCuREIqAqB4YmxA8dtReaeRZF2WCpZqfzgC9by4bohfA
y4m_0Azzvpc5MalZs7ILOvtVmbI8Cs0EEZ7aq54FYhGBlCCTRFaGgX9mc_-v0K5qwWwJ7dGE-ARuTrq7Vgr9amfSkZlMViY032-23g8isDc4DkpEwWE2668Dga36c3yxnpEdODhqWZ1y4MVBlvXyDPCnAFZP2qYVlDGCiuf_cv-2OG6WQ3jr9sA6_kozYCLFb2P23d2EnRXgV4JwM35vRZ4gw
zool
Progress!!!! So glad you're getting some time for the boat!!!
Even this time is stolen time Mike....but the tide is changing....Im eager to get modern car problems off my mind,,,,,,15 and counting.,,,,,, Im winding down a car business I fell into to..
I also feel a lot better since I stopped going to the doctors, ....go figure :)
zool
I started messing with an early 80's 7.5 hp johnson I used on the 10' game fisher...I plan to test this boat on the local reservoir which is 9.9 or 10 max
y4myXedrAaF54IOYd9aJNOUj4S-ounTmLk5UrzTwU5ECQVuIEJKb58LZjSZ4pJVk5cf_UT9cPcYzaRqtlhM33vSwZuu2jK5QOd5WwQSkHsDCYRC7XyskwaOwG_ENPweuYEEpaxY1ROcNceIm6VSaG3Onw-8__UYM6pjtdVvEnUc-D4MON3txfBFflouuLehTwa4Q2sCHvTJQDSB4-yUvdHyMw
y4mN-BaaxPanjXsL4Sg8F--K_oclRMcsrE-yDN3_ZNvQ8M9a53UpUPmPuYYArFQGZ3eyXW2XkFzF1OfY5T_U6H7LXGccLTO78kP7oAlJKQd0Gy51kKyU4rUC6L7f5EbMuDS55DxzvxWhZq_ssMiL2naXkAiKoORBXkfFRfX6axlFc_z6ZyCJUDPg4gZmtpl817p3HJQrGW5ynmE1oZPmoI8DA
It started but needs the carb cleaned art best.....im working on it here and there..
Woodonglass
I'm no Mech-a-Nec soooo, have fun with the motor. Your skill set will have it running like a top in not time.
