Glen-L WB Power Skiff Build
sphelps
Good call on the strips on the bottom ... Should make it seem to handle a little better than sliding around on a piece of flat plywood ...
Although that might be kinda fun ! :D
Patfromny
Like the strips, you will taper them all like the center one too right? Seems to be the way to go for water flow.
zool
Thanks gang, and yeah Pat, I plan to contour the fronts and round over the edges so the glass lays tight....those were just scrap pieces, ill probably use oak for them.
Im planning to skin the hull with S-glass...which will lay flat around the angles and edges and give the best puncture resistance.....I also need more E-glass for the Imperial...so looks like usc gets another order...
I was gonna put on the sides, but I think I need a second pair of hands so ill have to pull my helper off his jobs one day this week,
zool
OK gang got a belated update:
Lately ive been going thru the doctor circle jerk, with little to show for it.....but thru all their tests, they said the ekg showed a silent heart attack, whatever that means, lol.....but they told the admiral which triggered a defcon 1 for a spell. So the doctors and the vampires at the lab have me on a rabbits diet and whatever..but all is well ;)
Ive managed to steal some shop time when the admiral was out and moved this project along.
With some help, I got the sides skinned, basically we cut the ply a bit over sized, then put it on with a few temporary screws, then traced off the contour, removed the screw\s, and put it with a jig saw. then rescrewed the sides on and filled the indents,,was a bit of a chore,,
sphelps
Hope ya get the ticker stuff under control Zool !
The skiff looks great ... I could see where you would need an extra hand installing the side pieces ...
archbuilder
I have to try one of these wooden boats......just as soon as I get everything else done lol! Looking nice Mr Zool. I had one of those "heart attack moments", One night in the hospital and $17K later they figured out I have acid reflux! Glad I have good insurance! Hope you yours is a whole bunch about nothing also!
zool
Thanks guys,
I decided to skin the 1st layer of cloth with 17oz, to get good abrasion resistance, I plan to follow with a few layers of 4oz finish cloth before fairing....I laid out a full drape and am letting the wrinkles settle a bit before spreading that much epoxy.
Woodonglass
Sorry about the ticker!!! I now have 9 stents! I hope I'm DONE!!! Boat is looking really Good!!
zool
Update:
So last i left off planning to skin the outer hull in cloth, but ive decided against that. Now I plan to just barrier coat the wood, and paint. I need to move this to another work area, so I want to get it faired and painted, so I can flip it and move it out.
This is where i left off.
y4mZO42UyL0WCg7ASaqSFstKnck7u42ron8-W2bvQV-nwj3ZdkZK0s9FqJdaKQK9Rn3B1RVXFR7Wh7Q2bwUHDqL114IKy41phaBTjPN5dwPXt28S9w9_q11gFOFjZVTaBtTXMy1kPEbmGKiIFqQyEFpvWtZm1_vUXptEfHFxYL-jiqgsrWTRAzwyaNwOuXlW_DkfrgzzhR6kA0IIW_lfopNNQ
Im using 405, 406, and 410 for bonding, filling, and fairing
View attachment y4meCG-w5n4qgga_NUroZqIxfinUJpHLrqV7qmSfOqqB11ijUdRWadH_2YUp3aFDis-9aoEwPCJJNpfFclEG2GFU1opuJhgD6NWC
zool
zool
Backing up a step or two, I started pre=sanding the hull with 100 grit on an orbital. In hindsight, i wouldnt have coated the screw tops with epoxy because its a paint to sand back to even, and when done, there is little to no coating left. Its better to just fill in the screw holes with the fairing mix and sand from there...bit I did the task of sanding each screw area flat, and the rest of the hull with it.
View attachment y4mnp6GX8Bkl8dTyGXBS4q8pu9cq7F2vHvZkbVeDTa5rNwcAUQ1KMWw3kqKoM3flKsLywf2rqlhlVcxjqJJPJ-7fvnG2-3gAMLO3
View attachment y4m5SOIDvnhSTmLND9bzjUcMznQQcgX1ctzUmhM1xeENp_qqAV8q_ann0NYqTdITN-P3Nc42VTd7IZ9sjFZPzUE0gy7aEEpmS5oi
View attachment y4mXCoU4bzP9bARk3lse_x48JLe6fif09jsld775dn2M3xXPWP_YekU_81q04lKgcZgUHSbc8TWUy11CwRsP7GzybIBQOIhKOLsV
zool
I thickened some rein with a mix of 405, and 406 to fill in the gap on the nose and transom bottom. There was a triangle gap at the transom bottom because of the transom angle meeting the flat bottom. The nose gap is just a void left between the nose board and outer skin, which will be covered with a hand shaped nose board made of oak.
View attachment y4me5vV9n-fm63vgGucNY-QStsk2Kkp0eQ85SOdCCUgi9URg3xwVValwsZs00ktHFFK-1Ojf0z5kSeN8f_N415-oL6J6Ig0vJ0zE
View attachment y4mrYBRvuKmUzR_WPPRG1cr2SQ_w5Hs3cpi9jdkPwYmKndJW6Lle-FMhJe3SNx4AX8GrJpv8yQ2pg8V6Ckpa8Sm87lwEKcApXzis
zool
Today I mixed up a batch of resin and 410 to a thin, wet mix to fill in some voids and seams, and serve as a base to start feathering, Ill follow up next with a few sessions of a dry mix to feather it out into the field,and fill any shrinkage in the screw holes....
View attachment y4mG0xAxJI84avWgi-5vmPUqXFciX2AgvAYEEJFEZPx0zEf0HvoyjO4nwr0Ry64M8c76DovYcIssqRdtQaLZtdsRWT0hk7QQ6JR5
View attachment y4mCsVAKCF-5PsWIwDUjl1aoAnH6_gy1wtoQqtrAjMBry7gU8EXotWI5K-k5h1biwqzGN-ZheKygrzyR0qyeuRLLdXVR_TMqQ3hR
View attachment y4m8S_96b6a4w5ywq6G5jlm2JSTf-fg1UC_7oNkZUvJxvrybsMBjMEP1h0U-lkD9dlqcrmvz3ReeY9Z9atQGHa2DviTp3RuHj19y
kcassells
So the 8 hr. energy beverages really do work! Oh man you go boy!:)
Thanks for the fiaring demo too.
