2.3L omc swap to 4.3L merc project.
As promised I will document the swap for anyone who may be interested.
Ayuh,..... Wicked Cool,..... Bring it on,......
It needs a Bigger carb,....
Speak
Some questions about today. And some pictures of what I did today if anyone is interested. I installed a new gimbal bearing into the transom assemble, and installed new U joints on the drive.
Question one. In the upper gear case, the seal that keeps the water out, I believe its called the upper drive, lower drive shaft seal, the one you can pry out with a screw driver to change. Which way does the seal face when seated? Does it face out with the spring? I think it should but I noted the spring facing into the cavity before I removed it.
Question 2. In the bell housing where the shift rod/shaft goes upto the bell crank, which way does that seal lip face, up or down?
New gimbal.jpgNew Gimbal ready to go in.gimble to go in.jpgTapped in to start. tried to hammer it in with pipe.jpgI tried to use this 3 inch pvc pipe. Tried to shorten it but still was what I felt was to much beating it in.using a lawn mower blade to pull new bearing in.jpgUltimately used a long carriage bolt with this old lawn mower blade with a block of wood on the other side to draw the bearing in.wood on the other side with 3 inch pvc pipe.jpg
Speak
Gimbal installed and greased.jpgNew bearing finally in. Was a ***** for me to do. I didnt think it was that hard to do , but man it went in hard the entire way. the last little bit I used a back end of a chisel and a hammer to work it the last little bit down.new ujoints to start.jpgu joints being intalled.jpgujoints being installed 2.jpgujoints being intalled 3.jpgujoints being intalled 3.jpgNew u joints installed..jpg
Speak
U joints went easily enough, greased them up. Waiting for my water pump kit so i can button up my drive and put the new stickers on it. :)
Rick Stephens
Seal lips always face what you want to keep out or in. The upper case output shaft seal thst you can pry out only keeps water out. So lips and spring down. The intermediate shift shaft seal only keep water out, so both of those also face down towards water.
Speak
Clips off Alpha.jpgI remember taking one of these clips off the drive when pulled the drive, but where does the other on go? why is there two. I went thru all my pictures and cant identify them.
Rick Stephens
Grounding lugs. Look at parts diagram for sterndrives to see locations. Or look for a screw hole right next to one of the lower right side upper gear housing to bell housing stud mounting hole and the other one is in upper where it sits on stud from lower by the shift shaft.
Speak
thanks Rick. I can picture it now - will go check it out.
Speak
Guys, i need to replace this bolt due to rot. What grade of bolt is this? Is it a specific bolt?
Rick Stephens
I went ahead and replaced all my transom bolts with OEM from Merc. I also use Vibra-Tite on all steel bolts and studs going into aluminum. Keeps down the electrolysis and corrosion.
Speak
Okie dokie - I'll replace with oem -thanks Rick
Ayuh,..... Per Don S, I put Perfect Seal on every bolt I might have to take apart someday,....
In the 3 or 4 years I've been doin' that, insteada never-seize, All have come apart, Nicely,....
Speak
if Don S used it then it must be good- I'll get some - thanks Bondo
