- Joined
- Apr 17, 2002
- 71,465
As promised I will document the swap for anyone who may be interested.
Ayuh,..... Wicked Cool,..... Bring it on,......
It needs a Bigger carb,....
Step one is to complete the transplant- THEN we go for increases powerAyuh,..... Wicked Cool,..... Bring it on,......
She's used to it - lol doesn't complain anymoreTHAT is a nice deal!
Your wife is gonna kill ya for keeping boat parts in bed ...
New Gimbal ready to go in.
Tapped in to start.
I tried to use this 3 inch pvc pipe. Tried to shorten it but still was what I felt was to much beating it in.
Ultimately used a long carriage bolt with this old lawn mower blade with a block of wood on the other side to draw the bearing in.
Rick Any thoughts on post 45?Nice. Good luck on your test run
Question one. In the upper gear case, the seal that keeps the water out, I believe its called the upper drive, lower drive shaft seal, the one you can pry out with a screw driver to change. Which way does the seal face when seated? Does it face out with the spring? I think it should but I noted the spring facing into the cavity before I removed it.
Question 2. In the bell housing where the shift rod/shaft goes upto the bell crank, which way does that seal lip face, up or down?
thanks Rick. I can picture it now - will go check it out.Grounding lugs. Look at parts diagram for sterndrives to see locations. Or look for a screw hole right next to one of the lower right side upper gear housing to bell housing stud mounting hole and the other one is in upper where it sits on stud from lower by the shift shaft.
I went ahead and replaced all my transom bolts with OEM from Merc. I also use Vibra-Tite on all steel bolts and studs going into aluminum. Keeps down the electrolysis and corrosion.
if Don S used it then it must be good- I'll get some - thanks BondoAyuh,..... Per Don S, I put Perfect Seal on every bolt I might have to take apart someday,....
In the 3 or 4 years I've been doin' that, insteada never-seize, All have come apart, Nicely,....
