I've been having issues with this oil pump (96 ELPTO 75 hp Mercury). It's time for me to bypass or disconnect the oil pump - and mix my own 50:1 gas (2.6 oz per gallon). I've approached that point of no return by pulling the oil tank. Next step is to cut the oil line and plug it. Before I take the leap, I'd like to see if anyone can confirm that I'm going to pull the correct sets of wires:
1. Bottom of the oil tank, 2 blue wires (Switch Assembly) - pull apart @ connectors.
2. Enricher Valve has yellow and black wires sneaking through the motor - Disconnect @ 2 screw connectors.
Pull off the oil tank and mix 50:1.
Will the motor still have a high temp alarm? Any way to test that once this project is done??
Thanks in advance !! zul
