Bravo Shift cable tool (drive end)
Speakrdude
Ensign
Can someone measure the thickness of the shift cable tool that sits on the bell housing.
Thanks!
When my cable is properly set, the underside of the cable end is 7/8" from the face of the bell housing, in neutral. See: https://www.facebook.com/photo.php?f...7&l=f93ee53cf7
Agree with the 7/8 once the other end is adjusted using the cable extension tool and it's installed within spec. 111 shift tool.jpg
Now if you have a band new cable it should be pre-adjusted and all you need to do is adjust the height (3 inch) of the pivot point and install, no other adjusting is required. Bravo shift adjust.jpg
