Hey guys, I am rewiring my boat setup to make it less complicated to look at while it is in rebuild mode and need your experience with it.
First thing, I am wanting to install a rocker switch on the console to cut on and off the main source to all the electronics. Meaning I have to cut on that switch so the the other switches may work. I haven't seen much details around or I suck at searching right now, but how would I go about wiring it up? Do I have to get a battery switch that will connect to the rocker switch, then that rocker switch to the fuse panel?
Also, will a simple SPDT switch work on a bilge pump to turn it automatic vs manual? I was thinking a DPDT would work as well, but the wiring for that type a switch seems complicated based on the original switch, which broke off.
So my basic switch on the console will do this
Switch 1: "Battery Switch" to supply power to the fuse panel
Switch 2: Gauges
Switch 3: Nav Lights
Switch 4: Accessory (Cig lighter, radio)
Switch 5: Glow Light
Switch 6: Bilge pump 1 - Pump water into
Switch 7: Bilge pump 2 - Pump water out
Switch 1 - 6 was going to be an ON/OFF switch while Switch 7 is pertaining to the question above.
Switch 2: Gauges
