scout-j-m
Thread starter- Joined
- Jul 31, 2009
- 643
I just bought a 1967 Evinrude 9.5 hp Sportwin (model 9722M). The compression was between 65-70 psi on both cylinders using the recoil starter. From everything I have read, that is acceptable and would likely go up if I used a rope on the flywheel and re-tested it...plus maybe more after a decarb. The seller sent me a video of it running, it just ran really rough at low speed. So with ok compression and at least enough spark for it to run I feel good about diving into this project.
However, I came to post a question. This motor has had a bunch of holes drilled into the top cowling and the dampening foam removed directly above the carb intake. Obviously this could be due to a few different things but I was wondering if these motors are known to have exhaust leaks or if there is any other good explanation for these holes on this particular model?
