bobrock123
- Joined
- Apr 23, 2016
- 9
I am looking for some professional advice. I have an 1989 or so 150 mercury. It has been on the boat for two years and was steady at 140deg, at 5800 rpm... Now at 3000 I get 180deg. If I go beyond that it will hit 200deg at WOT. I have changed so far ..... Impeller, Poppet valve, Thermostats. I pulled the powerhead and cleaned out the adapter plate. There was sand in there. Reassembled with new gaskets.. Took it for a test ..... It is a bit better ... 3000 rpm 160deg At idle I have about 4psi and 18psi at WOT. compression is 130 on all cylinders .... I am at a loss as to where to look next my serial # A933666 Appreciate any help....Bob
