redmen62
Thread starter- Joined
- Aug 7, 2011
- 103
Hi everyone,
It's been a bit since I've been around... which I suppose is a good thing, that means nothing has gone wrong! Until last weekend that is... I'll try to keep it brief but get it all in
Put the big boat (3 Regal 277 w/ twin Merc 228s (305, 4bbl carb) and Alpha 1 drives) in last Friday and it ran great on a quick ride from the launch to the slip. Went out again on Sunday for a Mother's Day lunch cruise (35ish mi round trip) 30mph cruse up and about 1/2mi outside the breakwater on the way back a metallic rattling type sound from the port engine caught my ear, think rocks in a coffee can. Threw the throttles down, scanned the gauges (all looked normal) and killed the engines.. tried to start it, and it wouldn't even crank. Limped back on the stbd, and the dock brain trust got together... someone suggested the starter, so I gave it the old "hammer test", after 3 love taps it fired right up, but still had the sound. My thought was the starter is 33yrs old, it took a crap and somehow the bendix engaged and was mashing on the fly wheel after it started and is running. Replaced the starter today (kind of interesting if you're a normal to big sized guy), fires right up runs great with no rattling noise... boom diagnosis confirmed! Went to go for a quick test run at speed, well now the port engine won't ****. Am I missing something here? Checked the neutral safety switch, seems fine (eng won't crank in gear, and "button" on side of shifter is engaging/disengaging), shift cable linkage on the engine is moving, shift cable from engine linkage on the engine to the outdrive (through transom and boot/bellows)
Is there a reason I'm just missing here? It seems WAY too coincidental that I have 2 major system failures back to back like this
No clue if it's even remotely related, but the port tach was intermittently not registering last week also... shook the wiring under dash and that seemed to fix it. Chalked that up to running cables for new GPS
Thanks for the help!
