Hi Speed Overheat SOLVED!
rick3452
Just wanted to thank everyone here for their help in suggestions on my overheat issue with my 2000 M/C 5.0 with a bravo 3
After changing the manifolds and elbows, Mercruiser impeller kit, Checked the Heat Exchanger for blockage (none) Removed and replaced the Thermostat and nothing helped. So this weekend I installed a 1 1/2 Through Hull Sea Water pick up and Tee'd it into the existing water pick hose from the transome. I took it out last night and ran it hard for a while and it stayed on 160 Solid! It was really lacking water due to Bravo-itis, the closing of the intake hose.
Thanks again!
Fort Lauderdale
Rick
HT32BSX115
Thanks again!
Fort Lauderdale
Rick
Can't remember your thread on this but it sounds like the drive water pickup is clogged with corrosion/debris/barnacles etc....
I have a FULL closed cooled 454/Bravo using only the drive water pick-up and it maintains normal temp at WOT in 85 degree F water.
I would have probably would have went to a thru-hull too if the drive was clogged!
Glad you got it fixed!
Regards,
Rick
