urbanredneck
- Joined
- Mar 30, 2016
- 111
Hi guys.
I have had this issue occur in the past. Thought I had it resolved, but apparently not.
Motor : 87' E40ELCUD , running premix.
I go to start motor with normal procedure, and it just cranks. No start. Starter engages. Fuel gets pumped in.
History: Bought boat/motor this winter and had some typical bogging, hard starts, etc. Its got fresh carbs, new plugs. Starting running better then found a bit lower compression on bottom cylinder.
Did a nice de-carb, and seemed all my problems went away. Its been out a dozen plus times lately. Running like a champ. Starts great, idles great. WOT great.
I get out to the lake this weekend, same ghost no start condition pops back up. First time months ago when this condition originally occured, motor died when i put it into neutral from drive. Motor died, and wouldn't start for a few hours. Went out the next day to mess with it, same issue. Then boom, was fine and it statyed.
Ran spark test, hard to tell in the sunlight (inline tester, by myself 10ft away). But seems as that's what im missing. But its only at random times.
So Someone mentioned it was ignition related. I can't seem to troubleshoot the issue since it WILL start eventually, then will start every time, first crank after that .
So this weekend. While dead on the water, i took apart the control/shift box. Everything looked great. I touched nothing. Put it back together, boom. Started right up .
So, say I have a coil or power pack on it's way out. Would it be so, if it worked some times, and not others, or would it be toast all together?
Couldn't be neutral safety switch, that kills the starter on my motor.
Dead mans switch WILL cut spark if its engaged however.
What other troubleshooting can I do if the motor is in a mode of wanting to start? How can i troubleshoot it when it's not 100% broken? How can i identify a possible worn component?
Any other tips on what could be causing this would be fantastic. Its got to be some electrical fluke. Everything else is solid. And once its done being a freak, starts up no problem.
Sorry for the novel. Thanks a bunch folks.
