stretch751
Thread starter- Joined
- May 17, 2010
- 14
Install of new coils, points and condensers on a 1970 25 hp Evinrude model 25002C. I worked in a gas station in the 60's and thought I understood points. Bringing the lobe and rubbing block to the stamped word "set" area and adjust points to apx .02 is no problem but on rotation the points never close. Using an ohm meter and readjusting the points so they open on time results in a gap of no more than .0015 and that will never work. What am I missing? Also the factory timing marks on the flywheel have been damaged and only one can be seen and used for the ohm test / set.
