wateranchor
- Joined
- Aug 9, 2016
- 7
What is the firing order on a 87 60hp Johnson motor? Which plug is #1 ? And can you hook an automotive timing light up to this motor to check the timing?
Top plug is #1 What is happening very seldom does timing ever go out on an outboard motor unless something catastrophic happens. It is not a good idea to mess with it.
The motor at fist would fall on its face when I'm About 1/4 throttle and I would hit the choke and it would take off good. Then it started fouling the plugs very easily.
