Baylinerchuck
Thread starter- Joined
- Jul 29, 2016
- 2,740
1990 4.3L LX with 670 hours. D428255.
Alpha 1 out drive.
Troubleshooting a WOT issue and lack of power. Performed a compression test, #1 117 psi; #2 120 psi; #3 112 psi; #4 120 psi; #5 114 psi; #6 115 psi. Taking into consideration that my gauge seems to read 5 to 10 psi on the low side as best as I can tell by comparing to a few other pnuematic gauges I have, are these readings normal, or a bit on the low side?
This motor has a quadrajet 4 bbl that I just rebuilt, so I'll be looking at that again.....
All the typical maintenance stuff has been done on this Chaparral 2000SL, plugs, wires, cap, rotor, timing, fuel pump cleaning, fuel line replacement, fuel filter install, pickup tube inspection, sea foam, oil and filter, shift cables adjusted. Barely will get on plane and runs at 3000 to 3200 rpm with throttle fully advanced. Oil pressure reads around 50 psi. Put stock prop of 14.75 x 21 back on. Verified secondary plates open, however top plate on secondary closed. If I manually open secondary top plate, rpm falls. Divorced choke working. What's strange to me is when cold, divorced choke pulls plate closed, engine idles at 1500 rpm. There is no high idle cam on a marine carb. When choke slowly opens as engine warms up, idle also slows down to 900 rpm at full open choke.
Am I right to be going back to the carb for further investigation? I have heard from auto mechanics that quadra-junk carbs can be finicky, ( their words).
Any help is appreciated. As info I bought this boat used and is my first I/O. i have two 4 cylinder Johnson outboards that I resurrected, but this 4.3 is a weeeee bit different,
Alpha 1 out drive.
