Is this more like what you wanted to say?
Motor was running fine, then shut off. Ended up being a bad driver coil, replaced yesterday. Now it will not crank. Has spark, gas everything to run. Just want it double checked. Wiring, gas lines, nothing is wrong. Hope someone on here can point me in the right direction. Also new points, condensers and spark plugs
"then shut off" do you mean, you shut it off, or, it quit?
How are you getting spark if the engine is not cranking? What hp is it? Better yet, what is the Model number? Then we will know which engine to look up. Right now it sounds like you put it all together with something shorted out.
