- Joined
- Mar 8, 2009
- 44,296
Interesting stuff,.. Is this ian nheritance to just Bravos,.. .. Or is there 'Alphaitis' too ?
Was hoping an Alpha dude would answer this one in the last thread, but since that didn't happen, hopefully one will come in and clear it up if I mis-speak.
The Bravo uses a plastic cone bushing which is screwed into the hose which causes it to be held in position. Part of the hose extends past it and this rubber is what causes the issue with the Bravo. The fix is the kit which removes the screw in plastic bushing and replaces it with a tube and a rubber bushing which goes around the outside of the tube.
This does happen to the Alpha because it uses brass barbed fittings which go inside the rubber hose and is secured with hose clamps. The gets soft as all rubber over time but there is no swelling at the end
