Cracked and soaked fiberglass motor mounts on Sea Ray 200cc
ripazka
No Title
ripazka
Epoxy kicks in slooowly because of the low temperature in the garage. Im working at the minimum temperature. Good thing is that I have plenty of time to fool around :D
ripazka
No Title
Clamps away and the hole done.
ripazka
No Title
Some prep things before first lay up.
ripazka
No Title
First lay up done.
ripazka
No Title
Transom waterproofed. Some minor preps next and then installation. :)
ripazka
Thanks guys.
My transom water protection plan for the next 20 years:
Im planning to do some holes to transom wood to all points where I want to attach something from the outside: speed meter's bracket/sensor, sterndrive's lube oil hose and drain plug's screws. Im replacing the wood with PB. Im hoping that will reduce the chance of water to soak into the wood. The drain plug and speed meter I will connect with bolts instead of screws. That way the only weak points are the main transom bolt holes. Those I can seal a bit easier to last AND they are through holes so maybe* I can see possible leakages (well atleast its easier to waterproof them properly compared to screws). Screws are a bit hard to control I think. Any comments?
ripazka
Today I finalized the transom wood and builded up more boards to press the transom wood against the hull. I also grinded the narrow areas of the hull with dremel extention tool to reach +4 inches so the epoxy tabbing may attach well.
Im going to install the transom wood on Saturday. Let's see how it turns out ;)
JASinIL2006
Good luck with your transom install. Hope it goes smoothly and you have some nice pics to share!
I found that doing a dry run or two - to make sure I knew exactly what had to be done and how quickly - was very helpful.
ripazka
Thanks for the tip! Good idea. Pics will follow!
ripazka
Transom is installed now. I have no pics yet. Installation went very well but the smooth transition near the drain plug was very challenging. Epoxy PB heated up a lot and the viscosity was lost and it started to swell. It took a lot of time to get it right. Now Im just going to wait it to cure and then finalize it to get it 100%.
ripazka
I think thats the disadvantage of the epoxy. It kicks up slowly even though I took the fastest one. Pros is that it does not smell at all and its still the only choice for me at the moment.
ripazka
No Title
Ok here are some pics for you! There are still some fine tuning left but its easier to do it when I remove the clamps. And nope, its not a huge air bubble at the top of the transom wood. Its just a sanding mark / epoxy that reflects some light :)
