Mid 80s 150 Mercury Black max
I have the serial number 6551090 stamped on the back bracket. Cant find this number anywhere.. Also, searched the Belgium serial numbers... Any ideas why or what year this motor is? Where on motor would I find the serial number stamped? thanks for help
Dukedog
on early models with all numbers and or start with a letter (pre fat block) you need ta add a "0" (zero) in front... if on a merc marine site usually adds 0 for ya.... ya might get lucky with a number stamped on tha welsh plug.. looks like a freeze plug on top of tha block.....
that number with 0 added comes out a 60 hp motor on merc marine site?
double check tha numbers for being what ya say!.. if just one is off it will screw up tha whole thing....
also if one bleed line springs a leak might be time ta replace all of 'em
Yegboats
serial_sticky.png 1looks like it falls around 1984-1985 As Duke said double check the serial number b/c any conventional search didn't work, and lists the 60.
Dukedog
no.... did you get any "paper work" ie: title, registration etc. with tha motor?
Dukedog
ok.. as for year, there is a build date stamped on tha block... its at tha base of number two cylinder on tha "block half".. kinda behind tha bend in tha timin' arm.. stamped 1/8" numbers.. m/d/yr... might be hard ta find/see but its there.....
Still trying to ID the 150 Black max
On top the carb i found 1374-5427..
On starter 2-21-84
Stamped on block 858 8346
