- Joined
- Jul 18, 2011
- 19,649
I found it works if you use soap, and have the bolts just holding the rubber piece in. Once it slides in, it can be pulled back out some if need be
Thanks for your guidance on this. :thumb: Yes, soapy water. Initially, I had been using the soap on the tube and rubber insert. Just now, I also used soap on the rubber hose itself, as it fits into a tight channel in the transom assembly. I found that I needed to get the position of the hose pretty much exact so that the plastic tube would go in straight. The soapy water on the hose portion allowed me to make slight adjustments of the position.
Here are a couple of pictures . . .
The main issue is that the plastic tube would be misaligned and not able to protrude through the installation fixture.
With soap on the rest of the hose, I could adjust the alignment a bit from the outside of the boat.
I did get the port drive hose installed . . . :clap2: :happy:
So, I'll see if I can finish up the starboard side using the extra soap on the hose.
In other news, I retrieved the 7/16" box wrench that fell into the unknown, but subsequently lost a 7/16" socket to the cause.
On the brighter side of things, Formula boats has announced the 330 CBR now is available with outboards
