62cruiserinc
Thread starter- Joined
- Oct 30, 2009
- 295
I just finished my outdrive dolly that I made from a modified Harbor Freight Motorcycle jack that was on sale this week for $69. The modification is to install a sliding outdrive holder on top of the jack pads. The slides are 220lb heavy duty drawer slides from Rockler ($20). This way I roll the jack near the transom and adjust the height and side-to-side to line up with the bellhousing, and then slide the outdrive forward until everything is hooked up properly and bolt it on.
Since my boat is on stands on a gravel surface, it would be somewhat difficult to push the whole jack forward smoothly and not have it hang up on pieces of gravel or move sideways, especially since the jack wheels are rather small. That's why I decided to make a separate sliding table on top of the jack. It slides forward 20", and even with the outdrive all the way forward it doesn't tip the jack.
Below are two pictures, one with the slide retracted, one with the slide extended fully.
Steve
Steve
![0317161158b[1].jpg 0317161158b[1].jpg](https://forums.iboats.com/data/attachments/229/229649-ed9597964bfd886a9e4c223b6286d1a0.jpg)
