1973 evinrude 18hp head
wauto
What years of cylinder head will fit my 73 18hp? Can I use one from a 20hp ?
RCO
I believe any of the 61-up 18 hp heads will fit. The 20 hp of the same years is the same head as the 18. The older ones do have a slightly different thermostat housing, but will work.
F_R
25hp heads look the same but cannot be used on the 18hp because they are mated with different pistons.
wauto
My 18 uses external coils. The older heads don't have mounting bosses.
oldboat1
guess one simple thing you could do to narrow the search is to check for matching bolt patterns. Look up powerhead gaskets. If you get a non-match, that powerhead would not exchange.
hardwater fisherman
You might be limited because I think that was the last year of the 18hp, and the only year with external coils.
F_R
Great idea, but won't work. All the 22 cubic inch 18, 20, and 25hp motors use the same bolt pattern and gaskets (during the thermostat years)
oldboat1
apologies, wauto -- misread your post. Not looking for a powerhead.
(suggestion wouldn't have been helpful anyway....)
Curious, though. Is the head messed up beyond saving?
wauto
My head blew out a spark plug. Gonna remove and try a helicoil.
boobie
Why didn't you say that to start with ????
wauto
I thought it would be easier and more reliable to put a good head on.
oldboat1
Either way, resurface the head before installing/reinstalling (and fresh head gasket). I've used helicoils a couple of times, and had good luck -- can get up and running with one while looking for a replacement head.
