- Joined
- Jul 18, 2011
- 19,646
I have the QuickSilver Dual Controls on my boat, which I absolutely hate . . .
They are showing their age, and today I noticed what could be a growing problem. . .
Cruising along at about 3400 RPM ( 38 mph) I noticed that when I put my hand on the control to adjust it slightly the RPM of the starboard engine suddenly dropped, like the engine had been shut off. I quickly removed my hand from the control and the RPM popped right back up and resumed as it was. All this was in about 2 seconds time. If I bumped the controls or moved them more deliberately, everything was fine. It seemed if I lightly touched the control lever the RPM thing would happen. . . this happened 3-4 times. So, I just left the throttles alone for the most part.
I was going to try a WOT run, because the bay was flt, but I did not want to risk having an engine suddenly shut down at WOT . . .
So, this got me to thinking, is the shift interrupter on the starboard control starting to get flakey? Is there a way to test this? Or maybe inspect it for wear?
Since I am not a fan of these controls ( I had the Kiekhaefer/Mercury Racing controls on my last boat) I am wondering if I should just upgrade to a set of performance controls with separate gear shift and throttle levers. :noidea:
Not sure what all will be involved in upgrading. Would I still be able to use the same set of cables that run to the engines? I don't want to open a can of worms during the season. So, I am wondering if I can easily diagnose the existing controls to get them through the season or should I just upgrade to new controls? (If it was a slam-dunk)
T.I.A. for any guidance on this.
