Racklefrack
- Joined
- Aug 6, 2017
- 44
A little context first: My wife and I want to buy a boat but we're limited as to the size we can buy because our max towable limit is 3,500#. We can't replace our tow car with anything bigger because we also tow the car behind our RV, which means we have to find a boat that works with the whole package we already have. That's the easy part, actually, and I've already narrowed it down to (first choice) a Four Winns Horizon 180 OB, (second choice) a Glastron GTS 180 or (third choice) a Bayliner 180 Bowrider... all outboards because of the weight issue, of course.
So, HERE'S my real question: Price isn't an issue, weight is, and that forces us down into the "entry level" market because they're really the only option that are light enough for us to tow. Normally I'm fine buying used vehicles, but buying a used entry level outboard boat makes me VERY nervous - I'm concerned the first newbie who bought the boat might not have maintained the motor the way they should have. I'm pretty handy so the actual boat itself isn't much of a concern, but I'm not much of a mechanic so the motor IS a concern.
Of course I'd hire a surveyor before buying anything used, test ride, etc., but what I'm really looking for is YOUR input based on the scuttlebutt within the boating community. Specifically - how common is it that used entry-level boat motors are maintained so poorly that they become a problem for the next owner?
I have a feeling I'm overthinking this issue and that it's not nearly as big a problem as I fear it is... but I have no way of knowing that. You folks might. If it turns out that the problem is as bad or worse than what I think it may be then I'll just buy a new boat instead, but I don't want to pass up on a great deal on a good used boat if my concerns aren't justified.
You guys are tapped into the community, you know what's going on out there. I could use some help.
Thanks!
Thanks!
