Marinemp
Thread starter- Joined
- Sep 19, 2017
- 38
Me too that's more than I paid for the boat !! How do they expect people to have 4 grand laying around for a repair ??I need to change jobs...
I appreciate that advise ! I guess I'll have to epoxy and vinylForget the deck stuff. Does not stick on and does not last. Adhesion and UV issues. I talked directly to mfg and that was their answer. Just go with acx, bcx ply. On another note waterman will definitely steer you in the right direction when it come to tin.
When I install my deck can I use sheet metal screw instead of rivets ?
You can, I had good luck with the Sharx marine screws not coming loose but just think about what material the screws have to hold onto and all the vibration in a boat.If you're lucky 2 teeth on the screw are hanging onto aluminum.
The Sharx got some bite and don't shake loose. I still prefer rivets tho....
Sorry fella’s I’m not done or checked out I just haven’t worked on the boat this winter it’s in my buddies barn with no electric running to it and this crazy Lake Erie snow has held me up! So I just ordered epoxy for my deck I’m going to make I went with us composites 625 epoxyBummer....I think the fella check out of doing the rehab.
Since I've been around I've not seen one single Islander completed as an Islander but many started and they just disappeared. I'm beginning to think they're a cursed vessel.
Really looking forward to seeing one come out new again.
