DunbarLtd
Thread starter- Joined
- Nov 8, 2016
- 357
Ive read couple other motors did same thing. Not sure what caused it or if it damaged anything but i hope not. That would suck.
You want plugs to be slighlty oily that just means its running a little rich which is preferable. But you want it running rich because of how far out the aur screws are not because theres a flooding issue. You could lean it out. Dont turn the screw in any further than 3/4 turn from lightly seated or itll run too lean and hot.
If you lean it itll idle smoother and the plugs should lose that oil. At least you will know if you have a flooding issue.
I would think if the air screw doesnt make a difference its tip is worn down and letting air go by but im not a guru by any means.
And it takes a trained ear to hear slight differences. Just adjust the screw either way til it chugs (too rich) or pops (too lean) and set it to halfway between the two. Turning them til it dies is fine. You may have to adjust several time to get it right so it doesnt die on you but chugs or pops. I read some guys start 1 turn out. Some 1 1/8 out and some 1 1/4 out. Im going to start at 1 1/4 and see how it goes.
It make take some tinkering and patience of course to get it right.
Also, I think doing compression test would be 1st thing to do. Thats always the advice i see.
Then make sure u have nice bright blue spark on all three cylinders. Make sure to ground the plug wires to the block.
Then make sure fuel issues are resolved. No leaks and diaphragm is good. Filters clean, No water in the fuel....
A link and sync is important.
Im new to these outboards so im still learning as i go but theres a ton of info on this site if you search around. The stickys at the top of this forum are full of good stuff. Hope you get to the bottom of your issue because i may have the same issue as you.
I havent taken it out but once since i replaced that boot and i wasnt too happy with it. It ran ok but definitely something seemed off. I should get it back on the water by this weekend. Ill take notes and come back with the results.
Hopefully its something minor. A full rebuild is not something i want to deal with.
