Racklefrack
Thread starter- Joined
- Aug 6, 2017
- 44
Just purchased a 2012 Glastron MX185 with a 4.3 MPI 220 hp motor / Alpha One with 1.81 gearing -- 72 total hours on the whole boat. Dinged prop was replaced by dealer prior to delivery a week ago with the same 23P prop that originally came with the boat.
Today was the first chance we'd had to take her out (since the test drive). 30 minutes into the ride we decide to open her up to see what she'll do... most other forums report this boat will do approximately 52-ish mph at 4800 rpm, depending on setup, conditions, wind, etc. Mine went 48 mph at 6000 rpm... and I didn't even have the throttle arm pushed all the way forward, I had maybe another \inch or so to go.
Clearly something is not right. Even with a 23P prop on a 1.81 stern drive, this engine shouldn't turn 6000 rpm, right? Aren't they rev limited at 4950 or something like that?
I'm thinking that the tach is not set correctly - maybe it's set up for reading an 8 cyl instead of a 6? Doesn't it make more sense that the engine was actually turning closer to 4600-ish rpm at 48 mph with a 23P prop on that 1.81 drive than it does that the engine was turning over a thousand RPM past it's rev limiter?
I'm really new to boats so I could really use your help getting pointed in the right direction. Is there something I can look at on the tach itself to see if it's set right? Is there there something I can check on the engine to see if the rev limiter is hooked up / functioning properly?
Please remember to use small words and simple ideas... I'm really new to all this
Thanks so much!
