andrew j cox
Thread starter- Joined
- Feb 11, 2015
- 149
I have on occasion used bi carb to dissolve the salt crusty corrosion, has anyone else tried it as an actual bath to soak badly crusty parts ? Cokes abit expensive to fill a 20 litre drum I need to pickle my head and water jacket cover.
The oheat sensor in the jacket was cactus so I knocked it out are these still available as a new item?
To fit trim n tilt will a later mid section work I can get a mid 70 s set up with T n T, be nice to have , I could attempt to jerry maybe a Merc ram onto it if I remove the wierd Tilt bracket on the stern clamp.
I will split the case later and pull the pistons out any traps for new kids with these?
