tigger3650
Thread starter- Joined
- Apr 7, 2012
- 130
Looking at all the couplers online. The only ones with a shaft that protrudes beyond the rubber are the triangle style. They are also the only ones that have a grease fitting. I have not ran it without the drive, however, with the drive on and straight it doesn't rattle. I don't think running without the drive would tell me much.
I did pull the drive this morning. Found the new ujoint broke where the c clip goes, casing the joint to slide, broke the grease fitting off and can see where it was hitting the tabs on the bearing retainer nut. That ujoint was a moog, and appears to have slightly taller cups than the ones that came with my kit. I'm off to Car Quest to get another joint. I'm going to put the smaller joint on the aft portion and the new moog to the front. I don't think this will solve the rattle, but I think this may have been a consequence of the rattle.
