Why stay with an under performing 4 blade?
I went from a 4 blade to a 3 blade that improved my hole shot while increasing my top end speed.
In my case, I dropped a pitch (17 to 15) going to the 3 blade to bring my RPM. The drop in pitch (and reduced slip) increased my WOT more than enough to make up for the loss in pitch. The smaller pitch combined with a vented prop allows the motor to spin up quicker out of the hole improving my hole shot as well.
17P 4-blade to 15P 3-blade, that was more a function of selecting the correct prop pitch to get the engine to it's WOT RPM, opposed to 3-blade being all around better than a 4-blade, since the 4-blade wouldn't allow the engine to reach it's WOT RPM. Dropping pitch while also going to a vented 3-blade prop, I could see that the boat would have much better holeshot than the non-vented over pitched 4-blade prop... You found a very good prop match for your rig, when before it wasn't a good match.
I tried several 3-blade props and was never satisfied with their overall performance. Then went from a 19P 3-blade to a 18P 4-blade and every performance aspect was vastly improved, except top speed as expected. Fits my needs perfectly, unless heavily loaded or at altitude, then a prop change is needed.
89retta chose a 3-blade prop that's not a good fit for the boat, needs more pitch since it's overshooting WOT RPM. Jumping up to a 21P 3-blade would most likely yield top speed improvements he's seeking, while sacrificing some holeshot.
