JohnnyGuy
Thread starter- Joined
- Aug 24, 2017
- 196
Hi All,
My brother-in-law and I co-own a 12' tinner with a '76 15hp Johnson as our main source of power.
My brother-in-law was recently given his grandfather's '75 2hp Evinrude. We plan to use this on the boat as a kicker for when we're trolling.
The motor hasn't been run in over 10 years. Cosmetically it is in fantastic shape for it's age. The pull start does engage and you can turn it over (gently checked it once, just to ensure it wasn't seized).
The throttle seems to be really stiff?
The gas tank is a little loose (looks like it's missing the fuel tank retainer springs (P/N 330808?) on the underside of the tank?).
The handle broke years ago and the current handle is HALF of a bow saw (funny by it works).
Our plan was to:
1) Pull the spark plug and check the plug for any internal corrosion, at the same time check through the plug hole for the same on the cylinder/cylinder walls.
2) Assuming no corrosion squirt some 2-stroke oil into the cylinder from the plug hole and put the plug back in.
3) Disconnect/drain the fuel lines and carb (tank is empty, not sure if anything in the line/carb).
4) Pull the engine over with the spark plug in but disconnected to lube up the cylinder/cylinder walls with the oil from step 2 above.
5) Check spark with gap tester.
This is where I am wondering what to do next. We plan on doing the water pump kit and carb clean (kit), but would like to check compression first to ensure we're not spending money on the kits for nothing...
After step 5 above, will it be OK to hookup the compression tester and check compression at this point in time or should I be running the powerhead to burn off that oil before checking compression?
The next steps would be (assuming compression is good):
6) Drain and replace LU oil
7) New waterpump Kit
8) Carb clean and new kit.
9) New spark plug
10) Give 'er a test start (run a higher oil ratio fuel mix (25:1) for the first little bit of running the motor?).
We've already purchased a factory service manual and are anxiously awaiting it's arrival.
Are there any other recommendations on starting up an old motor?
I had read a few articles about spraying fogging oil into the cylinders instead of oil?
Clean out the fuel tank with seafoam or something?
Should I be changing the fuel lines at this time to? If so, does anyone know the line size off hand? I was thinking a clear line from the tank to the carb would be handy to have.
Also, if anyone had a handle they'd be able to give me the measurements on from one of these old 2hp, I'd really appreciate that, as they're obsolete and I have the means to be able to have a replacement made.
The fuel tank retainer springs that are mentioned above (#330808) are obsolete, I have found two used ones at $20/pc, but If anyone here has a solution to keep the tank from rattling around on the cheap, I would be happy to hear!
With regards to the throttle being stiff, I'm hoping that there's a screw somewhere to adjust tension on the armature plate or something? I had read another post about the throttle being too loose and coming out of position when running due to vibration. Hopefully my problem can be solved by doing the opposite? If anyone has any comments on this, it would also be appreciated.
Thanks in advance for any comments and recommendations.
Cheers,
JG
Our plan was to:
9) New spark plug
Cheers,
JG
