Hey all, I guess ill start from the beginning like every good story does. I had some extra cash and had been looking for a nice sturdy boat that would compare to my father in laws 17ft Mauntauk (whaler) has an 88 spl on it (Johnson). Its a very basic boat though in the bays and harbors its rugged and steady. So I found this Sea Ox 1983 17ft with a Johnson Sea Horse 70hp on it.
Bought the boat and towed home which was a nightmare in itself, Trailer rotten and decrepit. Hey I got a decent price I thought, a very expensive ferry ride from main land to Marthas Vineyard then back. $$$$$$$ Ticket was more than I paid for the boat!!!
110miles north and here I am with and over heating issue. let me state that I did do a bunch of research on my vessel and motor. I have found countless threads of people having issues and people still to this day loving their 40 something year old motors (Johnson Sea Horse 70hp). So I thought its a fifty fifty chance of this thing giving me problems after I go through the basic maintenance. So with that said I removed L.U. and ran through the water pump/impeller cleaned everything. From my little knowledge on this engine it was mainly run on the sandy shores of the CAPE. I.E. SALTWATER DUN DUN DUN!!!!!! Anyway I cleaned up the lower unit and replace all LU gear oil. removed and re greased prop shaft, I replaced wiring harness and Starter solenoid also replaced fuel pump, after installing a brand new Battery and a couple hours of messing with starter fluid and cranking it over. She fired up and Purred, I got to say I was pretty surprised with how well she came to Idle and stayed steady, I almost couldn't believe it. I throttle up and Rpms reved up I looked down at the prop it was spinning with smoke coming out. I was thrilled I let it run a couple min longer and then shut it off and walked away from it while I went back to work for the rest of the week. I came back to the engine today and started up fine and let run for 30 min or so between idle and up throttle, I forgot to state I am using Outboard Flushing Muffs hooked up to my well water (ill come back to this in a minute) I have a nice stream of steady water coming out of telltale and also when I rev up the engine the stream increases in power ( so does this mean my water pump and impeller and LU components are working and sending water up to at least the lower part of the block?) After a about 15 min or so I thought I heard a beeping sound like and alarm. I had dreaded this moment before I even got the thing running haha. Any way I am stuck. I removed thermostat housing and cylinder head case/water head case and ordered new gasket. Parts like little valve grommets and inside housing doesn't look so bad as in crusty or flaky but it was definitely Dry in there no water ran through that today. to confirm over heating I threw water from the hose on it and it boiled and fizzed also i noticed when i turned engine off the tell tale spat out quite a bit of steam. Also was smelling some burning paint. I never used a Temp gun and i do not have a temp gauge set up coming from this engine.
Please help!
Thanks J!
Please help!
Thanks J!
