FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
turn the drive all the way to either left or right, then you can remove the 4 screws. to totally remove both trim limit and trim sender, you need to at least pull the drive. as i understand, to replace, they come as a pair(kit) now.
Curb your enthusiasm . You will have to pull your drive, and remove the bell housing hinge pins and pull the housing back so you can access the 7/16' cap screw on the clamp that holds the wire's sealing grommet. You'll want a ratcheting 7/16 box end wrench with a pivoting head to access the cap screw. You'll also need strong small hands.
my contacts on my trim switch, not the sender were gooped up when i got boat and would intermitenttly work until i cleaned them. i also had worn, exposed copper at the base. i used permatex liquid electrical tape to seal for now.
