Accessing trim sender
Someguyincali
How do I remove the trim position sender on the merc stern drive? I can't get to half of the sender without remove major components.
kulle
turn the drive all the way to either left or right, then you can remove the 4 screws. to totally remove both trim limit and trim sender, you need to at least pull the drive. as i understand, to replace, they come as a pair(kit) now.
harringtondav
Wow. Thank you. That was so easy. Haha
Curb your enthusiasm ;). You will have to pull your drive, and remove the bell housing hinge pins and pull the housing back so you can access the 7/16' cap screw on the clamp that holds the wire's sealing grommet. You'll want a ratcheting 7/16 box end wrench with a pivoting head to access the cap screw. You'll also need strong small hands.
Someguyincali
I'm fairly certain I have a bad trim gauge. It's stuck in the up position. I'm going to test voltages going to the gauge later.
Leardriver
That looks like the trim limit switch, the one that prevents overtravel.
kulle
my contacts on my trim switch, not the sender were gooped up when i got boat and would intermitenttly work until i cleaned them. i also had worn, exposed copper at the base. i used permatex liquid electrical tape to seal for now.
harringtondav
Not trying to be a wet blanket. But I've been there with.two boats. Replacement was the fix
