807447A14 = 350 Remanufactured Partially Dressed Plus-Series Crate Engine
Application Alpha 275 hp @ 4800 RPM, for MerCrusier Alpha and Volvo SX applications. Features high flow Gen+ iron heads, roller camshaft, 750cfm, 4-bbl carburetor, mechanical fuel pump, Thunderbolt V ignition with knock control, stainless steel valves, Hypereutectic pistons, high flow oil pump, water pump, harmonic balancer, oil pan, engine harness and flywheel. Operates on 87 octane fuel.This new engine is a power solution for MerCrusier Alpha and Volvo sterndrive applications
SKU: 714-807447A14
Alternate SKU: 714-807447A14
Category: Engine>Quicksilver Remanufacturing & Returns
https://www.**************/mercury-q...-807447a14.htm
If the link don't work then just search the model number online...That's where the info above came from.
