Aaron Huyser
- Joined
- Mar 19, 2019
- 65
Hi all,
I have finished rebuilding the engine. When I say rebuild I mean its been completely overhauled. I just finished getting everything back together meaning harness, lower end, shift assembly, throttle assembly, etc. I'm at the point now where it would be time for fresh gas and a first start up. Saying that is there anything special I need to do? I know I will need to run a break in cycle according to the manual which is fine but don't I need to set timing on the engine? How do I do this if I can't run the engine up into the high RPM that the manual calls for to set timing. Also I oiled all components during assembly but the powerhead sat a week or two while I rebuilt the lower end so should I add a little extra oil through the spark plug holes? Should first startup be on muffs? I know these may seem like silly questions but any advise ya'll can give for a first start up will be a huge help. I'm very mechanically inclined and have a good skill set But I would like to get the advise of others to make sure I do things to the T anything I would need to do for first startup please let me know.
Take care
Take care
