Coach Brown
Thread starter- Joined
- May 22, 2019
- 2
I have a 1992 Mariner 9.9 and last year I had the carb worked on because it would not start. Once fixed, the engine cranked right up. I did not get to use after that one crank and the boat sat up for a year. Now, it will not crank. I put new gas and got it to crank for 4 seconds after cleaning gas filter. Also, it will crank when spraying starter fluid into the carb and run for a few a little bit then. Yesterday I opened it up at full throttle and it ran for about 5 seconds like that before dying out. When the engine started running the primer bulb lost all pressure as well and it will not always get firm when priming. Should I start with replacing the bulb or should I go straight to the fuel pump? Any help will be help this teacher and coach out!!!
