ScottWyler
- Joined
- Jul 11, 2016
- 32
Good evening I have a 1993 Evinrude 200 ocean pro when I bought the boat the motor ran fine. I winterized it and come the spring time I have no spark on all six cylinders. I had a mechanic diagnose the problem and fix it, it turned out to be a bad timer base. I then used the boat two times before it failed me again... One day while driving the boat the RPM went crazy I heard some loud clunking noises and it shut down I had to get towed back to the marina . I did a compression test when I got back and I have great compression but no spark in all six cylinders again.. mechanic came down and told me that I spun the hub on the fly wheel so I purchased a preowned Fly wheel from an outboard service place... after we installed the fly wheel tried to start it and again no spark on all six cylinders so then I bought a power pack which was the culprit. So with the new preowned fly wheel and the power pack we were in business. I have the motor running at idle at the marina and it’s fine then I go to take it for test drive and what do you know it shut down on me and would not start back up the weird thing is it wanted to turn off when I was in gear but when I put it back in neutral it stayed alive but after a while it just turned off and now it won’t start back up and again no spark on all six cylinders I had to get towed back again. I have put over $2000 in parts and labor into this motor what do I do and what is the problem any help is much appreciated thank you for taking your time and reading this
