jerryjerry05
- Joined
- May 7, 2008
- 18,185
Remove the plenum on the lower cowl.
4 tiny screws and LOTS of room.
Once you get up to .040 over then you get into rejetting the carbs.
The block removal, the exhaust pipe, held on with 4 bolts.
One of them usually breaks. I just don't take them off and remove the adaptor plate and pipe as an assembly.
I have a tree I use to lift the motors.
Or make a lift out of 4x4's
The blocks not heavy, just awkward.
A small fine rat tail file can do the job of beveling the edges.
You don't need to remove much at all.
Do I need to remove all 4 pistons in order to separate the cylinder block from the crank case? I can see where putting all them needle bearings back in place through the carb ports will be challenging.
The best way is to split the block.
Use needle bearing assembly grease when you reinstall.
Any other grease won't release/melt as quickly as needed.
IF??? you can hook a nail in the grooves??? Then it needs another bore job.
Once you get past .030 and up to .040 and above you need to start rejetting the carbs.
Look for a new block or even a complete motor.
Saw one on FB in Fl. complete 200$ Look around.
The harmonic balance puller usually requires the 3 holes be drilled and tapped to the next size.
!/4 20 to 5/16-16???
Myself I never had much luck with that kind of puller, the 3 jaw almost always did the trick, one time it didn't work(nightmare).
You can split the cases without the pistons coming out.
It's just easier to handle when sending to a shop for boring.
Heat on the crank end shouldn't get hot enough to hurt the stator.
Don't get it so hot it turns red.
You should replace the seal under the stator sop.
A little heat where you see sillycone helps release the 2 half's.
Where do you live?
???------You have to remove the power head.----Then split the crankcase and block.-----Then remove the pistons / rods and crankshaft.----Not sure why folks are always looking for a short cut.
A 3 jaw puller may be totally the wrong puller to use.----Are there 3 threaded holes near the flywheel nut ??-----First I have heard of -----" non magnetic welding rods " ---tell me more.
?----I am going to blunt here.------Those rods are not ---" new " ----I started using that stuff back in about 1981 I believe !!----You have you be careful on a flywheel as there are magnets that could be damaged at 800 degrees F.
The flywheel does have 3 threaded holes around the flywheel nut. I just got back from shopping and bought a 3 bolt wheel puller instead of a vibration dampener puller.
Here's a pic of the break
Was this caused by the puller?? or Hammer?
IF....using a 2-3 claw puller you need to put the claws at the bottom
IF.....using the threaded hole; make sure you buy the strongest grade-bolts possible (do NOT rely on the supplied in the kit)
