SSTKO81
Thread starter- Joined
- Jun 1, 2009
- 354
Good morning! I’ve been running down ignition gremlins and now that I’ve got this licked it seems there could be a fuel problem. (Long story made longer)
this engine had to have a new crank and #2 piston due to spinning a bearing.So it’s been blown Apart and back together, timing set to 6* and will run if the idle is held up in the 1100-1500 range. When cold starting it will immediately try to run but dies. After that some pretty aggressive feathering of the throttle has to be done to find a happy spot. If you can get it up and running for a minute or two then you can bring the idol down to around 700 to 800 RPM long enough to make timing adjustments throttle adjustments etc. But as it continues to warm up it gets more difficult to keep running. RPMs will start dropping And you have to continually make adjustments to the throttle to keep it going when it does finally die it’s very difficult to restart. There’s a lot of backfiring in sputtering. I’m just not Sure where to start my search it feels like a fuel issue. But why would it only become an issue as the engine continues to warm up?
