Winterizing with 4.3 Merc
Tommyd13
So it is almost cold enough here to worry about winterizing. I have already unscrewed the blue plugs in the manifolds to drain the water out. I was wondering if this was good enough or should I run some pink stuff through the motor as well.
If that is all you did then :nono:
Would be good to know what 4.3, maybe a year
Need to drain the block,
lower circulating water pump hose
remove and lower hose come from the Alpha drive and lower to bilge to drain water out
Check the outdrive drain holes
Rick Stephens
Motor and outdrive must also be empty. Like AD said, everything according to the book. If the motor, manifolds, water pump, oil cooler and outdrive are dry, no need to antifreeze. To do the outdrive, lower it down as far as it will go on the trailer and probe the drain holes on the lower part to make sure they aren't plugged up. Water in the outdrive will freeze and split the drive case.
Lou C
Also there is a square plug on the forward end of the intake manifold that needs to be drained as well.
The engine is 2005 Alpha One Drive
Being a 2005 and your first post I'm thinking you have the 7 point drain and not the 3 point
It brings up more questions like its probably MPI, and which a serial number would help
You may have a blue plug on the circulating water pump hose, and if so no need to remove hose, just remove plug.
If MPI it would also have a blue plug just infront of the cool fuel on lower port side hose
https://www.mercruiserparts.com/bam/subassembly/31499/7801/190
